mono job
S a plastering
been working next too a house and they have had some mono done but the beads are only 10mm does tis matter whats the implications of this obvious its been hand applied to cut down on the mixing but in all fairness the job looks quite good to be fair
Yes it's fine base and mesh then beads on after.i never had a problem that way
So you spray a base coat on leave to dry then come back another time to put the top coat on , instead of spraying wet on wet and having done with it.
I think we are getting our wires crossed pal .we base and mesh. Bead over that then top and scratch day after weather permitting??
I think what owls means you bead up then spray it all on in one go without coming back job done so saving time that way
I was told by weber tech not to mesh accept stress points all brickwork or new block work to have Rendaid on first to even all the suction out
