kentnewbie
Hi All, this is my first post so don't bite my head off!:rolleyes)
I've got a damp patch on my living room wall. It was caused by a leaking down-pipe and as the house is old with lime mortar, it soon came through.
So, I've hacked off the old sand & cement render & plaster skim to the recommended 1 mtr high and have used some Dry Zone damp-proofing chemical along the mortar course, [9" solid wall, but I can only get into the first brick thickness as my drill isn't long enough but if that s the internal skin anyway then I reckon that will do the trick?]
So far, so good then, but, I also bought some of their 'Renderguard Gold' stuff which has to be mixed in with the new sand & cement render so as to prevent future problems. My question is then, how long do I wait before the new render can be applied [its a 1 mtr tall by 15' long area] and once that's cured, how long before i can apply new plaster? I'm assuming that I can use a multifinish plaster, or is there a specialist plaster that should be used instead?
Sorry if I've over-complicated this post, but i hope you get the idea of what I'm on about:RpS_biggrin:
Kentnewbie
Kentnewbie
