plasterjfe
Going onto old brickwork after a removal we normally base with parmurex with lankolatex in the base mixing water. it provides a great backround but I aint sure if I can get the parmurex in time.
has anyone used sbr in with other pre blended basecoats? such as lankolatex or sbr in ocr or uf base.
lankolatex and parmurex is a sure parex spec but I aint sure about mixing the sbr with other gear because of th chemicals in them. Krend only spec HP for old brick also not low polymers such as uf or an ocr.
And no, using Sand and cement with sbr aint on the cards.
