Airless
luckylad
Hi
I've been looking at the airless plaster and was wondering, do you have to prepare moisture resistant board like you would with multi finish?
Do those Graco mark v machines break down into smaller pieces, to get them upstairs and the like?
Only used the Knauf Airless. Still don’t rate the finish
It’s not silky smooth or as durable as proper skim. The finish is dead flat, but grainy.
It's perfect for decoration and it should be smooth.
Also it does go hard but only once paint is applied. Makes it mega easy to patch prior to decs
I sand it with 220 grit and it’s still gritty in my opinion. I’m a fussy c**t though.
Do you spray and trowel up on your own?
When I’ve done it, one sprays and one flattens it with spats. My mate did the spraying and spatting on his own on this one as I was busy boarding the next house.
