1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
Advice on rendering lightweight blocks
Discussion in 'The Plasterers Forums Information Guides' started by BadgerF8, Oct 17, 2017.
  1. BadgerF8
    BadgerF8 New Member
    Evening all,
    I have built an extension which is in lightweight blocks [Ytongs] which are fairly smooth. I am intending to two coat render 4/1 scratch [with or without waterproofer/SBR?] and 5/1 top coat. Now I have done a fair amount of plastering and some rendering but I want to get this right!
    The more I enquire the more different approaches plasterers use! My main concern is the fact they are smooth [ish] there is no scratching on them so I know I will have to key them. But should I prime the wall or just wet it? And what additives should I use in which coat? I suppose its about 30m2 to do and the plastering sand is already here!
  2. Dgplastering
    Dgplastering New Member
    Hi badger, if the blocks are thermalites (thats what they sound like) you will need a scud coat or id use micro gobetis a parex product to kill the suction. You van always check the suction by chucking some water on them and seeing how quick they dry or do a test panel scratch coat and see how it goes off
  3. johniosaif
    johniosaif Private Member
    I would use a render grit or sbr if there smooth , the mix ratio should be at a max 5/1 and 6/1 top coat
Share This Page
